I'm using the Econoline adapter on my oil cooler housing to get rid of the coffee cans.
I found a piece that might work for adapting my oil filter hoses to the econoline adapter. The alternative is to use the factory lines, and tig weld AN fittings on to the ends of the lines.
I need to know if the dimensions in the econoline adapter are exactly the same as the ports on the econoline oil filter housing.
The piece I've found is meant for the oil filter housing.
Here's some pics of what I'm talking about. The econoline adapter is the one on the left. (On the oil cooler housings pic)
I'm cross posting this to other forums, as I need an answer so I can get it ordered.
