Ok so my cousin tried to install a TS chip on his early 99..He did EVERYTHING correctly and after the install he attempted to fire up the truck but it cranks and no start. I noticed the WTS light is not coming on and the fuel pump is not buzzing. I checked the batteries,connections,PCM connection,pulled fuse #22,tried with chip out & in, unplugged the fuel bowl heater and nothing..there is a click that can be heard on the fuse block under the hood and at the module at the driver side front of the fender (behind the drivers headlight) It cranks over fast and volts dont drop after 8-10 seconds of cranking...IM GOING ABSOLUTELY CRAZY! and ideas?
