1 - 1 of 1 Posts
Bought this smoked, got 2 my place and it decided it didnt want 2 run anymore, of course n1 around here can test injectors 4 7.3 or 6.0, so i started fixing problems all new, oil filters/fuel filters, air filter, crank sensor, ipr, icp, all new injectors(started running again), rebuilt oil cooler(nothing like 1/2 gal on ground when turning over), then hpop was about 800lbs 2 low, new hp oil lines, just rebuilt turbo, not sure of miles as was told under 300k but od says almost 400k, truck a little hard 2 start but only cause im running lucas in it, no codes hard or soft, will rev up(no prblems) sounds like a beast, can spins wheels leaving drive but once start getting about 40mph start loseing power once at 50 pedal at floor and not much power i havent checked fuel pressure yet but i dont c that being problem im thinking something else is causeing but havent thought of yet
1 - 1 of 1 Posts
