This is a bit of a read, but I appreciate any help and guidance I receive. Recently my truck began having a sporadic issue. It goes to total power loss (like key turned off), backfiring, lots of white smoke, bucking, etc. It only happens at normal operating temperature and in the 2000 rpm range. It eventually clears up and runs fine. It has gotten worse as of late. I originally suspected the FICM, so I replaced with the stock unit. The hotter FICM is the only mod other than an EGR delete.
I hooked an EDGE monitor just to see what's happening when it has one of its fits. Here is the data I gathered that seems off:
*VGT% is all over the place right before, then spikes to 85%. Normally at idle is around 45%
*MAF-V normal at idle 1.5v. Drops to .3 or less when it goes into fit.
*MAF lb/hr falls out
I replaced the MAP sensor with known good unit. Do I need to try the same with MAF? What other tests or inspections need to be made? Is this a turbo issue? I originally thought fuel. Changed filters (twice). Pulled drain plug on lift pump to check for sludge, rust, water, algae. Seemed to be good. I'm just finding a lot of info and having a hard time processing it all. I had it to my mechanic. I don't remember exact code numbers but it was EGR (I assume from the delete) and MAF code. Will the MAF cause this much havoc? I feel there's something there that I'm missing.
