1 - 1 of 1 Posts
So I put in a used 6 inch lift I have a e99 and It was for a late 99 and up truck and I thought the only difference was the track bar, put the drop pitman and the tie rod are loose as **** my steering turns 90 degrees and does nothing and the tie rod nut is tight as hell...I haven't tried it yet but is putting a few washers on the tie rod bolt acceptable practice to bring te taper up? I check the parts dept and the tie rod end is the same part number up to 04 and doesnt specify e99 and not... If the washers don't tighten uP the gap on the taper wtf is wrOng?
1 - 1 of 1 Posts
