Okay I am over the automatic situation. I have a non-turbo 1991 IDI w/ a zf5 trans. My good truck is a 1993 F-250 ATS Turbo IDI with a E4OD. Now I know motors are the same. What all do I need for the swap, I have the whole donor truck, so far I have accumulated the trans, t-case, driveshafts, crossmember, clutch and flywheel, and pedal assembly from the 1991. Will I need anything else for the swap. What about the pedals will they work okay. Is there any computers or anything else I will need for the swap. Any help would be greatly appreciated. Also is it as bad to swap as I hear it is.
