1 - 12 of 12 Posts
I finally got my old truck to the dyno. It's a 91 7.3 IDI with ATS aftermarket turbo and 5 speed. I turned up the fuel pressure to the max, and cut off the muffler running a straight pipe.
I pulled 13 lbs of boost.
Horsepower 217.5 at the wheels (about 275 at the crank)
Torque 426.3 at the wheels (about 530 at the crank)
Howard
cool, those are pretty good numbers for the IDI?
Those numbers look good Howard!
Here's what I figure.
Comparison to stock trucks.........
More power than
1982-1993 GM 6.5
2001-2003 GM Duramax (less HP but more TQ)
1989-2002 Cummins
1994-1998 Powerstroke
About the same as 1998.5-2003 Powerstroke
I don't feel like the red headed step child anymore :woot::woot:
Howard
Hey Howard, I saw a Dyno report of one of the Turtle Expedition trucks that they had just put a new IDI 7.3 Factory Turbo in with a 4'' exhaust and the Hypermax air intake like I have and a K&N air filter with some pump tuning. It was in a Power Stroke Registry magazine I have from a few years ago. I may be a little off, but I think it was 227hp and 597lbs of torque. I believe these numbers, because my '94 can out pull my '08 6.4 and most of my 7.3 powerstrokes I have owned! It has twice the low end that any stock 6.0's I have owned had, they had more top end though. I had a '99.5 7.3 that was the pullin'st engine I have ever owned, I kick myself everyday for selling it. I had no idea what these IDI's could do if they were tuned up a little, I am super impressed! I know you have a straight pipe, but what size is it? I have a 3'' down pipe into a 3 1/2'' straight pipe, I am thinking of going to a 4'' to try and get my EGT's down. When I am loaded heavy the long grades push my EGT's right up to the 1200-1250 range and I have to back out of it. Where is your probe? Mine is behind my turbo, so I add 200 degrees to what my gauge says, at least that is what I have heard I am supposed to do, if I am wrong someone please correct me!
I believe your numbers too! I have a 3" downpipe (not squished) and 3" straight pipe. I don't know where the probe is located off the top of my head but my EGT gauge is off by 100 degrees. It always reads 100 degrees when cold. I still think the water/meth injection is the way to go. These guys sell stuff for our trucks including an upgraded injection pump, bigger injectors, propane, and water/meth injection. Read their site on IDI's.
Diesel Performance Specialists, Inc. - The Diesel Performance Specialists
Howard
Howard
My gauge never drops to zero either! Is this normal? I did not know it meant that it was off. If it sits on 100 degrees when cold does that mean it shows 100 degrees hotter than the temp really is? I have been adding 200 to my readings, but mine sits at 125 when it is dead cold. I wonder if these gauges can be calibrated to be accurate? Maybe a tech can answer my questions!
That site has some cool stuff for the IDI's! I think I could use new injectors and probably a new turbo. The fins look pretty pitted on the turbo and I have a slight miss when it is idling. I guess I should expect these things with an engine that has 295,000 miles on it. Thanks for the good info.!
Sorry for the thread-jacking but what exactly does water/meth injection do. I'm a bit of a noob and im looking to get some performance out of my 93 factory turbo in the future after i fix the rust.
1 - 12 of 12 Posts
