1 - 14 of 14 Posts
My 21 F-350 is getting leveled this week. Looking to run 35’s on stock rims. I understand i will need 2” spacer on inside on rear. Any thing else needed? Enough clearance between rears if running 12.5 wide? Any recommendation on spacer brands.
Anybody have pix? Love to see some others with same or similar set up
I was hoping you would have received some replies. I've got a F350 dually looking to do the same thing.
After further research, the spacer goes between the wheels. I ordered mine Sunday. I went with bora aluminum 2”
Still hoping to see some pix
I know this isn’t on stock wheels but these are 35x12.50r20 on my 2020 F-350
That looks good, is that stock height?
1.5” Readylift block under the front spring perch, Bilstein 5100’s on all 4 corners, SPC caster shims, and Firestone Red Label 7500lb airbags in the rear.
good reource is offset customs for the fact of there directory with look at the setups and get a better ideal if it will work on the trucks i know you know but make sure it is not going to rub on the brake and inner partson the bed and the dualls them selves is the most impornt that and dont be over 8.5 wide
Man I wish it was this simple with the F450
Reactions: midnightrider79
The F450 is a completely different animal. Its super expensive to do anything with it. Looked at lifting, minimal $20000. All components are bigger, and wheels and tires are 12000.
Reactions: ZMANN
He doesn't need to, I was just making a comment
1 - 14 of 14 Posts
