Just installed my dual steering stabilizer kit from pro comp. I was trying to eliminate the bump steer I keep having but it didn't seem to solve that. It did tighten up the steering compared to the stock stabilizer that had almost 200k miles on it
Sent from my SM-G925V using Tapatalk
You shouldn't have any problems with bumpsteer on a leaf spring truck. Alot of those trucks didn't even come with a stabilizer. You probably need to go through the front end of that truck and check everything out.
Get under it and have someone turn the wheel and watch everything. Then set the front end on jacks and wiggle and turn everything. You should be able to narrow down what is causing your issue.
Reactions: sasq40 and ZMANN
