1 - 8 of 8 Posts
So, I'm interested in doing a dual shock setup on my 2010. I want the one shock in front and one shock behind the spring look.
I'm wondering is it's as simple as I think I have found? Just buying a dual shock hoop that goes around the spring and then mount your choices of shocks?:dunno:
I have seen the Pro-Comp dual hoop, and I have a pro-comp 8" lift. Is there any other hoop or setup that may be better? Does anyone have experience with this?
I'm looking at the Bilstein remote reservoir shocks to do this with.
Thanks for the help!
The Bilstein remote reservoir shocks are nice, so are Fox or Icon. If you are going to piggy back the shocks make sure you have enough room in front as well, or you can remotely mount them. I know a few companies make some nice billet and silicone brackets that work well for piggy back or remote mounting.
I picked Bilstein because they are relatively cheap. Bilsten is pretty stright forward about what will and will not fit and Fox/Icon isnt. Any suggestions just for research purposes?
Also, i'm pretty positive there is room for the remote to be piggy backed, and from what I can tell Bilstein either sells a nice billet mount with the shocks now or has one you can buy.
Bilstein are relatively cheap compared to the others, and for normal driving with some off-roading will hold up fine.
As far as fitment, they are pretty easy to size. I know there are a bunch of vendors on here that sell them, I have dealt with Performance Truck Products as well as Top Gun Customz. Both of them have great customer service, and will be more than happy to answer any of your questions.
That's good to know. My truck doesn't go off-road at all so I'm more than confident they will preform well then.
I'll have to give those guys a call and ask them as well just to make sure I get exactly what I need.
Now, to just make it until September when I get back to the states.
Discussion Starter · #9 ·
This is mine with the Fabtech set up.
Are those dual hoops part of the lift kit or are they stand alone parts that I can buy and add to mine? Thats like exactly what I want.
Discussion Starter · #10 ·
Also, I hate to sound amature but...what all is involved? I've been looking around and have seen the ProComp system is ~$500 and the Fabtech one is ~$800, both without the shocks.
Maybe I was underestimating the install but I thought it was just the hoop and it bolted up? The ProComp one has limiting straps, bump stop extenders, and more. Are these kits made for vehicles that don't have a lift already? I'm really confused...
Discussion Starter · #13 ·
Discussion Starter · #14 ·
Discussion Starter · #16 ·
I think i've decided on the Procomp hoop. Any ideas on the measurements, or how to get the measurements, for the shocks? I have to let the company i'm getting shocks from know so they can valve them correctly.
Thanks!
1 - 8 of 8 Posts
