1 - 13 of 13 Posts
Hey powerstrokers,
So I was installing my Farmboy exhaust system and it sounds wonderful. I just basically needed a better looking 4" system than the bully dog one. But now I've got a 6" tip from him and man it looks much nicer:icon_ford:
Here's my problem, however: After installing the exhaust, then running around town for about 2 hours, my Check Engine Light (CEL) came on. So I pull the code with my SCT and it reads "1 DTC Found - P0000" I have no idea what this code is and am not sure if this is a type of foreshadowing on what could come. If anyone could shed some light on this code that would be greatly appreciated. I've cleared the codes several times and it still comes back a few moments later after starting the truck. List of mods is in my sig if you need this information. Thanks again and let me know if I can be of more assistance.
Sergio
My 2007, 4 weeks back put on the CEL :( and had the local parts store read and came back with P1335, EGR.
Asked about clearing and found ScanGageII unit I like was local and has some other things I liked. So purchased and cleared the codes. The CEL reappeared and now had a P0404 cleared and then the P0000 popped up.
The ScanGageII reads “2 codes” but only the P0000 was showing cleared twice a day for 2 days. :dunno:
Started asking and the most common reply was P0000 was the system needed to run some cycles for some time and it would clear so I quit trying to clear it. After about 3 days the CEL quit lighting so I checked for codes the P0000 is still there but the CEL is out. :dunno:
Has been about 3 weeks like this, the truck runs fine so I have quit think on it and have not checked for codes in 3+ weeks, just drive it. :crazy:
It would be nice if someone else to help on this code and what to do or not to do.
THANKS
:icon_ford:
Rice Hunter
YUP, YUP... I to have the P0404 code popping up. EGR DELETED.....yea,yea yea anoying my azz. I've been deleting for two weeks now. Ole lady saw it pop up and like.....what'z up with the light on the dash thingie. TIME FOR A NEW MOD!!!!
Now if I just keep running it it will go away eventually but still show up as history rite:dunno:
That history thing is my question. :(
Maybe that is the why ScanGageII notes 2 codes but only displays 1, P0000. :dunno:
:confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused:
why are you posting this so many times?
:ditto:I'm kid of condused why this dude has been posting this over and over. Anyway, here is an update: So my check engine light turned off the other day after church and hasn't been back on. I haven't tried pulling the codes yet to see if it is still there, but the light is off and that's what matters. I still have no idea why this happens, but hopefully it won't again
Sergio
Sergio
I was hopping a tech would check in and maybe look in to this issue. :)
And my CEL turned on one more today after almost 2 weeks and can only get the P0000 to appear even when the reader says it has 2 codes.
The other why some how after I post the list gets cut off some times to 10 or less postings ! :(
Its time to cut the list of new posting off again. :dunno:
Rice Hunter
DTC DEFINITION FOR P0000: No Diagnostic Trouble Codes Found
Rice Hunter
Not all code readers read everything
Some code readers come with a disc. May be outdated since current flash. Check factory and see if you can update over the internet. IF You have connection on code reader
Discussion Starter · #11 ·
Well my check engine light went away as the fella earlier said it would. It hasn't been on in a few days so I'm guessing there is no code present. But I will confirm that sometime. Now I've got another issue with the battery, but I will start a new post for that in case someone else has the problem I cam having. Thanks guys and I will keep ya'll up to date with this CEL.
Discussion Starter · #12 ·
So my check engine light came on this morning again and has been on all the way to work. This time when I pulled the SCT out to read the codes, there were none. It says "No DT0 Codes found," yet my light still remains on.
Now when I finished installing my farmboy exhaust I found an exhaust leak that wasn't too major, but enough to get some of that exhaust tape to seal it with. Could this be the reason that I'm throwing this code. I didn't think leaks would matter if there weren't any sensors in our exhaust system. Thanks ahead of time:icon_ford:
Sergio
Code P1000
The code should be a P1000 it means obd system readiness test not complete.(Any time a repair is completed and codes erased this code shows up).
In order for the OBD system to clear the readiness monitors and complete its self-diagnostic checks, the vehicle must be driven under a variety of normal operating conditions.All of the self-diagnostic checks have not been completed if one or more readiness monitors read "not complete".A number of factors,including emission repair work or a disconnected battery,can result in readiness monitors being set to "not complete".In most cases, the readiness monitors can reset to "complete" very quickly, but in some cases, a few days of normal driving will be needed to do so.
1 - 13 of 13 Posts
