1 - 2 of 2 Posts
Here’s my finished product
Pulled the stock panel, measured Center then drilled 1/8 pilot holes. Then got out the step bit and went up to 3/4 and I was good to go. I drilled ‘high’ off center, as a portion of the stock panel is tucked behind the top of the bumper. Here’s that shot
The lights came from etrailer. Verified Black is pos and white is ground. I wired the + to the middle wire on the lower taillight bulb, as all I was after was to have em on when the headlights are on. I made a grounding point on the frame for this and future lighting needs.
1 - 2 of 2 Posts
