1 - 9 of 9 Posts
Just finished up doing injectors and glow plugs on pass side of my 2003 f250 ccsb, came to the driver side and removed the glow plug closest to fire wall. Dropped the new one in and tried to tighten it down to find it fell over and wedged inside the head right next to the injector hold down. I had to push the glow plug down pretty far and bend it in order to remove it. My question is pushing it down that far like I did there’s no way I could have puncture the head gasket correct? On the rest of the cylinder looks like is just solid down there nothing to puncture just wanted to make sure. Thanks guys!
There is a thin plastic sleeve that fits in the glow plug hole to act as a guide, so that does not happen
would have been handy in your situation
You wont get to the head gasket from there -- there is a sleeve that surrounds the glow plug, but I don't think you would have hurt that
It pretty much went right past the hole for the glow plug and when I put the socket in there it wedged it up against the injector hold down. Sweet, I kind of figured it was ok considering I got it out without breaking any pieces off. Thanks for the reply, I feel pretty dumb lol
It has happened to all of us one time or another, all part of the job -- no need to feel bad
a short piece of hose works well also, push over the end of the glow plug and use the hose to turn the plug into the threads
That’s a pretty good idea, I’ll have to try that next time, had to pull the valve cover to get the messed up one out so it should be pretty easy to guide it in now lol
Look at some pics of other 6.0 heads. Looks like there is a hole in the same area where it got stuck. Just a clear oil passage I hope and not blocked off by a head gasket?
Picture of what happened, was wedged in there tight
Are you able to leave the glow plug in there if its wedged in pretty good? I'm dealing with this right now and I dont have much room to work with. It's on the passenger side, 2nd from the front of the engine .
I wouldn’t leave it in there, I was scared to bend it to get it out because I heard they will snap from being hollow. I ended up getting a deep dish socket over the edge of the plug and threw a long extension on it and just bent the crap out of it and it came right out.
1 - 9 of 9 Posts
