ooo it's a great time.. espically when I am just normal driving and people look at me cause my car is screamin and I'm not really going anywere:hehe: well when I have a weekend off I plan on doing it... can't wait to get it put in... and hopefully the e-cutout the same weekend:nod:Saweet:thumb::thumb: Thats gonna be fun. Got the cam in yet?oke:
LMAO:hehe: soon don't worry:nod:Hurry up with the Cam already!
what was his 60 ft. time? and really with heads also and only mid 11's thats really not that good:nod: and what size of a cam also?? my setup pretty darn close to someone else's he is running the in the 10's... but his weight is around 200 or 300 lbs lighter than mine.. and speaking of that was his car a vert? and really you can have a larger cam and this and that but just like anything if you don't have the right combo it won't run like it should...:nod: also how much power did he have?My buddies 01 SS we had heads, cam , exhaust, and a 12 bolt with 4:10's and we ran mid 11's. With the 150 shot it was high 10's all through a 6-speed.
LMAO:hehe: okay no more videos then.....:thumb:I don't want to hear it until the CAM is in it!
It was a 2001 Camero SS Patriot heads milled, gasket match port and polish, cam was the largest one out at the time and he had new valves springs and rockers. The 60ft I don't remember with the 12 bolt he made 402 at the wheels and with the spray it was 570's. He was launching off the limiter and didn't hit the nitrous untill he was out of the gate. On the 2 ten second passes we figured out the clutch was slipping (I wonder why :slywhat was his 60 ft. time? and really with heads also and only mid 11's thats really not that good:nod: and what size of a cam also?? my setup pretty darn close to someone else's he is running the in the 10's... but his weight is around 200 or 300 lbs lighter than mine.. and speaking of that was his car a vert? and really you can have a larger cam and this and that but just like anything if you don't have the right combo it won't run like it should...:nod: also how much power did he have?
stock seems right... the majority of LS1's dyno around 310 or so to the wheels:nod: but 591/591:dunno: to me that sounds more like the lift of it.. cause my cam's lift is .613 intake/.591 exhuast.... but if the duration really is 591/591 well then he must of had some major heads on there...:nod: and if he did then the power is really really low then... my duration is 230/230 and I should be maken around 400rwhp give or take 10 or so...The stock run on 310 at the wheels which a lot of us thought was weak. HP was 430 something before he put the 12 bolt in this was in 2006. He put larger axles and stuff in it too the cam specs I'll see if I can find out from him.
Cam specs 591/591 it was a nitrous cam from comp cams custom grind
