1 - 10 of 10 Posts
i did some searching around, and haven't come up with much....my power window no longer goes down, it is usually unresponsive when i hit the switch. every once in a while it will go down, but then i can't get it back up. anyway i want to take the motor out and clean it up or replace it, but i have no clue how the thing comes apart. anyone got any how-to info?
my dads pickup did the same thing and we took the entire door apart and everything and couldn't get it to work and then are hired man came over and pushed it really hard and it went up and we were afraid to roll it down for a long time and someone did by accident and it has still worked for 2 years now so try that i guess
it took my brother and i 5 mins to get it up last time. it still doesn't do anything, the switch just clicks
Did you try checking for voltage into and out of the switch and/or continuity through the switch before determining the motor is bad?
subscribing, i have the same problem mine goes down but needs help going up..
:dunno:
just replaced my motor, take the light cover located on the lower rear, take the small bolt out, then take the light socket out, remove the long narrow plastic located where the wing glass would be if it had one, just pull it straight out, next pull the front of the cover that holds the window switches, move the assembly, pull the whole door panel up and out. feed the switch assembly thru the panel, remove the panel. pull the plastic back from the front to where the window crank would be, there are several larger bolts, then there are 3 smaller recessed bolts, take these out after removing the speaker. reach in the speaker opening grab the motor take the 3 small bolts out and the motor will come out. 45 bucks @ auto zone.
ares would go down but not up we thought the motor was fryed too that could be the case but ares we tapped on and started taking out and almost had it out and it started working again so we put it back togeather and its been working ever since...I guess beating on things works sometimes lol
so i can take out just the motor and not all the tracking crap?
are there any tracks to grease? my window is slow to go down, but only at the bottom. there was some loud popping today and I thought the window was going to break. it was like it was getting caught on something
1 - 10 of 10 Posts
