The switch wont lok or unlock from drivers door switch, swapped with a working switch still nothing, what could cause this?
1999 Ford F450
Did you happen to look at wiring connector? I’m finding on my 99 f450 that connectors are corroded.
This situation also happened on another vehicle I owned in my life and it turned out that the door hinge just where the wires went into frame of vehicle, the coating on the wire rubbed off and caused a short.
Is this happening on passenger side door? And if so perhaps a fuse might have decided to retire.
Good luck!!
No the power transfers on both lock and unlock from drivers switch to passengers switch in both lock and unlock, so not wires in door I already took the boot off and looked
