I need to get to the fuel line on the driver side head, and its behind the accessory mounting bracket, the one with the AC, Vacuum Pump, and PS pump on it. I took 3 bolts out of it, the 2 on the top, and one on the bottom. There easily visible, on the inside of the bracket. It still wont budge. Are there more bolts? or does a pump need to come off?
that motor looks small!! i found it, i had to take the vacuum pump off.
