I noticed a pretty good vibration when I get up around 72 - 80 mph. Then, after 80 mph or so the truck will not vibrate as bad. The vibration is mainly under my feet and under the center council. So, it seems like it would be my U-joints on the driveline. I checked the u-joints and they all seemed to be fine - no play or broken. There is really no vibration when I am under 70 mph either. Does this sound like a driveline problem - u-joints? What else could this possibly be if it is not the u-joints?
I have a two piece rear driveshaft and not a 1 piece. Could I have a bad center bearing, because there was definately a little play in the bearing.
Thanks for the help!
