For a while I've been getting a slight thud when I leave a stoplight and sometimes when I initially release the brakes from a stop. U-joints and carrier bearing are new and in great shape. I did lube the slip joint with grease recently when I changed u-joints, it made no difference. Ring & pinion lash is within spec as well.
I read threads a while back where this was happening a lot but no one posted a definite cause. Is it the transmission getting worn (245k miles on vehicle) or a worn bushing somewhere? Many thanks
