ok, this is gonna be long,,,
Situation/what happened: traveling with cruise control set at about 73mph, empty i heard a terrible noise start. i had enough time to turn radio down to determine the issue when all of a sudden a loud bang and i was powerless. pulling over and observed NO driveline anywhere to be found.(had to walk back about 100yrd and out in farm field to retrieve)
Lead Up: after installing a 4" four-link BDS suspension lift in the front and 2" taller blocks in the rear and about 3/8"(per instructions) spacer in the carrier bearing i had a slight vibration/shimmy under Moderate to Heavy acceleration. (also running 35"tires MT tires)
Followup: Battling with Ford we agreed to split the bill 50/50 since i had barely 5,000 miles since mod and only 30,000 on truck total. and it was a minor size lift. they had to replace the complete rear driveline and yoke. Now i do still have a slight vibration/shimmy under hard acceleration.
The BIG QUESTION: what is the cause of this?? about 1/2 people say its axle wrap, other 1/2 say it isn't.. pics to follow..
