1 - 5 of 5 Posts
im thinking about buyin my buddies 94 F-350 idi he rolled it, but last year he replaced the transmission and had the rearend rebuilt. what im woundering is if i can take the leafs front and rear along with the axles and put them under my pickup a 97 F-250, also the transmisson and transfer case are they the same and does the 94 have a bigger smaller or the same turbo. im also lookin at puttin a limited slip or a locker front an rear. thanks for the help
All the suspension components should interchange with no problems just make sure to use the steering and trac bar from the F350. Not sure on the turbo but I think it should switch out also.
BIG TRUCK, SMALL DRIVER
Ditto on the turbo. The rest should work fine.
sweet thanks the only reason i asked about the turbo was i was thinkin a spare if i ever screwed mine up
1 - 5 of 5 Posts
