Anyone have any idea. Mine is just pushed on the fitting but not over the barb and it seems kinda of loose. I have been getting a code for the dpf pressure sensor so i just want to make sure the hose from the sensor is on correctly.
It only goes on up to the barb, however I see you have a H&S Mini. You should not be getting codes for this. I would get a hold H&S and see what they have to say. Make sure you know what software version you have when you call them. Good luck!
I had to put it back to stock so i can sell it and get a newer one. I thought it only went to the barb but it doesnt seem to be that tight on the fitting. It just slides on and doesnt seem to seal that well. I guess it must be the sensor is bad.
