1 - 20 of 30 Posts
New to the forum and had a couple of questions searched DPF until blue in the face so thought I would just ask and see what response I get.
I have a 2008 F-350 and would like to delete DPF system and tune, however was told by dealer that if do this the Check engine light stays on forever, is this true?
Is there an after market kit and tuner that will not make this happen?
Thanks for the help and advise.
if you buy a complete kit, tuner, dpf delete and all then no, there is no check engine light
cheap? used sct...
imma be honest. There are three words FAST, RELIABLE, CHEAP
but you can only have 2.
in all fairness, pm cobbsdieselperformance and [email protected] and ask them for budget dpf delete. i think you can get a single 4", sct with canned tunes, and dpf delete for like 1000-1250(but don't quote me, they aren't my products)
You could put a kit together with sct, and flo-pro exhaust for under a grand. Then you have the option to get custom tunes down the road once you get bit by the bug
Think I will jump in, tired of the 13 mph and the truck regin every 100 miles. The real question is what to get. I do not need to make a drag truck but would like a little more horsepower but nothing stupid, had the superchip in my 99 7.3 and used the middle setting think 50 hp not sure, but that is about all i need usually.
Don't pull lots of stuff but when I need to it is usually heavy.
I know other people have asked in other threads but does anyone have a recommendation for me to research. I have a local guy who is very knowledgable to put everything on and runs his own diesel shop (also drives the DirtyMax in drags).
Now for the wifes question how much louder does this make the truck she likes the quiet of the 6.4 compared to the 7.3 i had. I just want to keep the look of stock no verticle stakes for me.
SCT and a 3.5" DPF/DOC delete pipe. That way you keep the stock exhaust, but get rid of the DPF and DOC. Check out Cobb's Diesel Performance.
BINGO BANGO BONGO!
cheap? used sct...
Thanks!
Great to know Suggestions, as cheap as possible
Let us know if we can help! :thumb:
Just removing the DPF and Cat doesn't make it much louder at all. Most people complain about the *lack* of noise. I like the lack of noise. I don't need to draw any extra attention when I have nearly 600hp. I know it's there, and that is what matters.
If I had done mine over again, I would have left the stock tail pipe. You don't need an after market pipe till you want some ridiculous amount of horse power. Just get a 3.5" DPF/Cat delete pipe and a SCT tuner with canned tunes. You could get into that for way less than $1000.
John Cobbs mentioned a used tuner. I would be all over that, if I didn't already have something better. There is no problem with used stuff. And if John it's good, then I would buy it from him.
Discussion Starter · #13 ·
Thanks for the replies I am still looking around, wife holds the purse strings among other things. I definately appreciate all of the input and the more I can get the better I can sell this system.
do what i did... show her how much the truck costs to drive per mile based on fuel usage....
basically take your average fuel mileage, divide it by the cost of fuel and you have the cost per mile.
example 13mpg/2.70 per gallon = 0.21 per mile
now say you average a 4 mpg increase
17mpg/2.70 per gallon = 0.16 per gallon
that is a savings of .05 per mile. if you spent 1000 on a tuner and exhaust you could basically pay for the tuner by driving the truck 20000 miles. once you've done that, you start to actually pocket the savings.
i've seen almost 5 in mixed driving
on the small mileage topic i have a question. if i get the spartan tuner and the headers back exhaust what tune would i be able to run without the intake?
Sometimes you can run the 210 tune and sometimes it will suck in the filterminder. It depends on your truck and your driving habits. If you drive easy you could get away with the 250, but the first time you WOT it will suck in the filterminder.
lol ive mentioned b4 that i granny drive cause im used to a 4cyl SUV and on base regulations.
you can spend an extra 60-80 buy an aftermarket filter for the stock intake and run the 210 or 250
1 - 20 of 30 Posts
