1 - 20 of 39 Posts
I have finally decided to get rid of my DPF. I currently have a Bully Dog PMT and for my current budget want to do the DPF-R kit that will allow me to still run my PMT. I know most of you run Spartan tuned rigs (and I will one day join you!!) but I had a question... Is it easier to install and uninstall the DPF delete pipe only or the the DPF/CAT combo pipes? It seems it would be easier to leave the CAT and DPF bolted together by that big flange and pull it out and keep it in my garage and then when needed put them back in together. Is this possible? Or will I have to separate them anyways? Also, once I do upgrade my tuner to a Spartan can I still just use the delete pipes from DPF-R?
Does anyone on this forum currently run this setup? Reccomendations please.
If anyone has gone the DPF-R route my other question is do you have to install both the module and the emulator? Thanks for the help.
not sure on that setup, but i know just taking the dpf off and hooking the sensors to it is cake. and pulling the cat off is easy also, just depends on if u feel like doing both its honestly easier then washing the truck...i think stock is 3 1/2 inch right? thats what you plan on running?
To answer your DPF/Cat question, yes you can delete both of them together with one pipe, and not have to take them apart when you do the delete. And yes, you can buy one DPF/Cat delete pipe and be done with it. They are not setup differently for each tuner/module I dont think.
I have not ran the DPF-R module, but I have heard a lot of negative info about the one for the 6.4L Powerstroke. Apparently the one for the 6.7L Cummins is working fine, but there have been cases where the 6.4's running them have gone into regen randomly putting the truck into limp mode while the DPF-R module is on the truck. I am not saying to not do it, but I would seriously reconsider where you put that $400 before you do it. If you plan on doing the Spartan in the future anyways, why not put that $400 towards the savings for it....Just food for thought, not bashing your idea. Just throwing out there the reputation that the DPF-R has.
I dont know anything about that module but I believe it is easier to do teh dpf/cat delete as a whole. There are less bolts to take apart. It is a little heavier and I havent tried to put mine back in yet but Im sure it would still be easier deleting both. And any delete pipe you buy will work with any tuner.
I think you have a future and sales my friend :thumb:
:hehe: What about an attorney?...I want to be a real estate lawyer :nod:
ahhh attorney tell me you joking lol or do you like lieing everyday?? i noticed on ya profile other then trucks ya like golf, well other then work, truck and school im on the golf course myself have to hit me up if you down in La would have to get a tee time ha as long as you dont bring me to COURT if i beat you....:hehe:
I too say stay away from the DPF-R modules and save the money toward the Spartan. As far as pipes the CAT/DPF combo is much easier to swap. The only hard part removeing the stock CAT/DPF assembly is the fact that it weights close to 100lbs so a helper is great. If you remove it in one piece you don't have to deal with the gasket between the two pieces(alos $80 part if you have to purchase). We build a one piece pipe for easier install, less things to have to line up. Very simple to swap back for dealer visits, we even included the nipple for the factory pressure sensor. I suggest going CAT/DPF both when doing the delete.
Warheads on Foreheads
Guessing you could use a floor jack to help remove/reinstall both pipes together? Well on a stock truck anyways, lifted would be to high.
The problem with the floor jack is the shape of the CAT/DPF is round and tends to roll off the jack. If I have to do one myself, I use a tie down to hold the rear section up as my extra set of hands. This allows you to remove the hangers from the frame and front bolts at the downpipe, then lower the assemble in a "controlled" manner. I don't even remove the rear exhaust section (stock or aftermarket), I just racket strap it back enough to disengage to slip fit between the DPF and first exhaust section. as another note, I usually try the remove the 3 EGT sensors and pressure sensor while the pipe is still bolted in, this way you don't bang or break them on the way out.
I am no weight lifter by any means and I have no problems getting the DPF/CAT assembly back in by myself. I too will recommend you to stay away from the DPF-R's we have pulled them from our line of product as 08stroker250 stated above. They work awesome for the Dodge but the Ford ECM is far too complex to simply try and "trick."
Notice I said real estate attorney, not criminal justice or corporate. :thumb: And I love golf, been playing since I was 12 :nod:
You need to get me tickets to the Masters...:nod:
I have yet to go myself, and its only 2 and half hours away from me :doh:
lol Sad, I have been 3 or 4 times but that was 10 years ago. We should meet up one day and play Augusta National :hehe:
Wouldn't that be nice, I would be afraid to take a divot on that course :hehe:
I just installed my dpt/cat delete pipe and down-pipe back exhaust. All powerstroker67 parts. Did the Spartan tune with the DashDaq also. Currently running the 210 tune.
Getting the DPF/CAT off was simple. Unplugged the sensors and just dropped it from the down-pipe after beating on the resonator with a partial 2x4 and hammer. Problem was I couldn't negotiate the resonator/tail-pipes out over the axle. *Begin Rant* After 4 hours of blood/sweat (not quite any tears), removing a shock, lifting it as high as I could with my jack, I ended up going to a local exhaust shop and they put it on the lift and took it right out. Cost me $30 cash which I can say I should have done from the get go... *End Rant* Truck runs amazing now.
If you don't want to spend so much money get an livewire and you can run innovative or RCD custom tunes on that, a few vendors quoted me like $550 for a brand new livewire a few weeks back that is dirt cheap! I am still going to pick one up to try a few other tunes out here in a little while
Good advice, guess I overlooked the fact that something round is hard to keep on the pad of a floor jack:doh::lol:
1 - 20 of 39 Posts
