1 - 11 of 11 Posts
i have a towing chip plugged in right behind the e brake. would a sct x3 be stackable? my truck is a 1999 7.3. new to diesels truck came with the 80hp towing chip. idk if its burned to the ecu or just plugged in. any info will help.
thanks
will
Cant stack on a 7.3l They cancel each other out
thought so. is there any harm in removing the 80hp tow chip and programming for a bit to see how the truck does then plug the chip back in? i just don't want to harm anything. better yet i don't know how to get the chip i have in now out. its located behind the e brake pedal. maybe i should stop messing with my truck and just drive it how it is. idk if that's possible though.
any one have any ideas?
thanks
will
What kind of chip is it? If it is plugged into the pcm by the e brake pedal then you have to take out the pcm under the hood (10mm) then the 2 holding the pcm bracket out which are 7mm then you can pop it out. No it should be fine to take out. I would recommend getting a different chip either Dp, TW, or others. Custom is the best!
If you have any problems pm me
check the tech files. theres a right up on how to remove the chip. . . but i agree with everything kyle kleinss said.
alright mine is kind of like that i think. i dont have a cord coming out of it though. i think its just a single chip
1 - 11 of 11 Posts
