1 - 7 of 7 Posts
I am looking into buying a DP tuner chip for my 01 powerstroke. How hard is it to install? I have a superchip right now so all i know is the plug and play type. is the installation something that can be done easily on my own or is it something that id be better off taking to a shop to install for me?
I'm not very tech-savvy but I was able to install it easily. The instructions provided are clear and there's even a video in the tech files by Maintain that shows it step by step too.
yeah its an easy one, just take your time
the only bad thing will be replacing your tires :rofl:
I just did one today, along with an S&B intake...all together took me about 2 hours the hardest part of the DP is weding you hand in the engine compartment to get that screw off the PCM...then its all a steep down hill from there! Definetly get it man the tunes are sick....140 agressive makes the cars behind you dissapear!
i hella want the 140 aggressive tune lol. the only thing i am worried about is i have 4 inch exhaust that dumps underneath the cab. i dont know if it would be good to have all the smoke dumping underneath the cab. what do you think?
i think you should spend a little extra and get some sweet stacks coming up through the bed....or have some one weld the exhaust to come out the side before your rear wheel. I saw a truck at a truck show that had two pipes along the bottom of the cab on each side, probably about 6 inch or soo.....almost like stacks except underneath the cab
1 - 7 of 7 Posts
