I have a 2002 4 door that the red light stays on with all the doors are shut but the dome light goes off. I sprayed the door latches still the same. Any help would be greatly appreciated.
Thanks Wireman116
To clarify, your red marker light on the door stays on even if the dome light is off? Just driver's door or both front doors?
If so, you may need to check the wiring in the harness from the body to the door.
When all the doors are shut & driving the red door open light on dash stays on the whole time but the dome light does not stay on.
Thank you for your help
Gotta spray all the doors and open/shut them several times each -- the switch is on the door latch, so may need to remove the trim panel and clean or replace the switch -- gotta figure which one first tho
Sorry - I misunderstood. The advice above is good!
