1 - 9 of 9 Posts
So my door ajar light will not turn off and its keeping my cab lights on. So right now i have my batteries disconected cause i dont know if they will turn off. Does anyone know how to fix this please help.:dunno:eek:h and doors are shut and nothing is blocking them
spray the lock mechanism with wd40 or penetrating oil... the switch is sticking
Ill try that now and get back to you
CJ Ford your the man, that worked thank you.
yea i used to have that problem, i always keep an extra can in my truck.. . if it happens again and you dont have spray you can just pull the fuse instead of disconnecting the batteries, its a hell of a lot easier ha
Ill keep a can for now on stuffs good on everything, I have quick wingnut battery post so its fast to disconnect them.:thumb:
Discussion Starter · #8 ·
yea mine are all corroded out so they are a pain in the ***...
and by the way, our trucks look almost identical lol
"Good Man" I had two swich to the wingnuted posts mine where coroded to and i cant get stranded in the weather i have up here.:thumb:
no problem... the switches sometimes stick .. I had this problem with mine as well was my drivers side door
1 - 9 of 9 Posts
