1 - 17 of 17 Posts
Well, I've officially become frustrated enough to create a thread about this. I have searched high and low for the solution with no conclusive answers, and I have also PM'd folks who have had the same issue to see how they resolved it. No luck yet. So....
I was replacing my dome light with L.E.D. bulbs. Somehow I managed to touch both sides of the bulb with the metal sheet underneath the dome light and got a spark. Afterwards, my radio will not work. It lights up, the clock works fine if I push the menu button and it will allow me to insert and eject cd's. Additionally, I have absolutely no power windows whatsoever, and the 2 smaller lights on the dome light do not work at all when flipping the switch. The main center bulb of the dome light does work, however (when opening the doors, etc.)
I've checked the fuses and have yet to find a blown one. Fuse 601 is a 30amp and I'm not too sure how to check if it's gone bad. I know that this is the fuse for the delay and power windows.
Sometimes, but rarely, I can get the radio to turn on for a milisecond right after I've powered the truck, but still no luck with it actually working, the windows working or the dome light coming on.
I'm at a loss, so I'm really hoping somebody has a solution for me. Money is tight right now and it'd be tons easier if I could resolve this issue myself.
Thanks.
Reactions: dvdale
Let me check on Alldata and see if I can send you a wiring diagram to use in ad of helping you !!!....I think I can walk you though some pin point test and at least try to help........HALLA!!!
I had this same problem a few months back. I too was replacing my overhead dome lights and created a spark then the radio, windows, and dome lights went dead. I checked the fuses that you would think to check, and everything was ok, nothing was blown. But after doing alot of trouble shooting I found that I did blow a fuse, but instead of being the 601 fuse it was the #41 fuse. It is a 10 amp fuse for the instrument cluster. Hope this helps!
That was the ticket. Even though I had already checked all fuses before, I hooked each one up to a voltmeter and BAM. It was fuse 41. Thanks for the help guys. Hopefully this thread helps someone else out in the future. :thumb:
Reactions: dvdale
:icon_ford: Thank you so much, I was really really frustrated.
Crazy - I had the entire interior out of my truck today, both batteries disconnected, entire dash apart, did a sweet custom stereo install, put everything back together and checked it, the stereo worked great, I rolled the windows down to get some air while listening to my new tunes, then decided I would mess with my dome light in the rear. I changed out the bulb and went inside. I cam back out later to find dead windows. Thanks to this thread I will be able to sleep tonight knowing that all of my electronics should be there in the AM and Dry. Who woulda thunk. Thank you for the post. I rarely get in a jam, but when I do; I know where to find the answers - Right Here!!!!
Vendor
lol I love the ORG! same problem, same solution. Wish this was like cummin's forum and I could "Thank" those who contributed to this thread.
Man this was a life saver!!! I had the same symptoms. Changed my interior lights to LEDs but it didnt do it right away. Truck drove for like a week or 2 and then poof!!! No windows, no radio, no lights. Nothing!!! I changed the cluster and nothing. Very happy I found this!!!
Fuse 41 is a biatch!!!! LMAO!!!
Wish I found this thread when I had my problem recently. But I read the crap out of my manual and figured the same issue.
Good stuff!! :headbang1:
ok here is a new one i also am having a problem. i changed my bulbs to leds. i then blew a fuse so i replaced it. got the front set done and went to the rear set. when i was putting in the rear dome light it sparked then the front dome light flickered then there was no sign of life. so i check fuse again and it was fine. so i proceeded to check all fuses and nothing blown. so i said ok maybe i fryed this led bulb nope it worked in my wifes car. my map lights all work radio works windows work but dome lights nothing. any ideas?
yes all fuses are good relay is good also i checked fusebox and it is getting voltage. then i checked the dome light itself and the buld is good but there is no voltage making it to the dome light. map lights all work front and back but neither front or rear dome works with door open or with switch.
i checked both #41 and #35 they are both for same thing according to owners manual.
I LOVE YOU
I LOVE YOU BRO! Thank god I couldn’t find the stupid issue!
Thanks.
Thanks.
I had the sam
Thanks.
I had the same problem.
I LOVE YOU
I had the same issue. But the fuse that was blown on mine was 35. I would not ha
I LOVE YOU
I LOVE YOU
I had the same issue. I had a
I LOVE YOU
I
I LOVE YOU
I had the same issue. I had a short in
I LOVE YOU
I had the same issue. I had a short in the reflector light
I LOVE YOU
I had the same issue. I had a short in the reflector light on my door panel. Mine had blown fuse #35, instead of #41. I would have never figured it out if not for this thread. Thanks to all.
Had the same issue with my 05 F250, THANKS for bailing me out!
Bumping an old thread with some new information to try and help somebody out in the future.
2006 F250 Crew Cab King Ranch
My problem was after reinstalling sunroof, headliner, associated dome lights and controls-my sunroof, all windows, dome lights only worked when door was open but not by the switches at each one, and radio would not work. Everything else appeared to work on the truck.
I checked all the fuses associated with these and no luck. Was about to send off my instrument cluster to have the integrated relay repaired on it (had it removed and ready to pack) when I did one final check of all fuses.
Fuse 43, 10A, labeled as Fog Lamps was blown.
I replaced it and my sunroof, all windows, dome lights, and radio began to work.
1 - 17 of 17 Posts
