I'd check the oil cooler. Orings go bad over time and leak.
I recently had mine rebuilt.
i think you are correct, the more i look. will add rebuild oil cooler to list of stuff to do while apartI'd check the oil cooler. Orings go bad over time and leak.
i had already replaced the "easy to get at" hard fuel lines after one got a rubbed hole in it.I'd consider a non-ebpv turbo pedestal, possibly replacing the fuel lines as it's only a matter of time before the hold downs rub a hold in them. Pretty common to see and the main reason I designed this kit.
Up pipes if they are leaking.
CNC Fabrication 7.3L 4 line feed fuel line kit
Upgrade your fuel-system with our 4-line-feed fuel-line kit designed to eliminate the infamous #8 injector knock and fuel starvation in the #1 and #8 cylinders during higher RPMs and heavy throttle while towing.cncfab.us
