1 - 7 of 7 Posts
For my trans temp. gauge, I had to supply my own wire for the temp. sender. The only thing I had was 18gau. The guage seems to work correctly, but @ times seems a little slow. Is there a recommended size wire for temp. senders? Is the 18gau. putting resistance from the sender to the gauge? If it's anything, I'm referring to an electric, short sweep, AutoMeter Z-series.
Wire gauge is related to resistance yes, but a bigger wire = less resistance and a smaller wire = less. If that helps you then :thumb:
:tard:
18ga should be a good size, my AutoMeter Pyro which is an electric sender also, is like 22-24ga wire...
Thanks, fellas. I was worried I would've had to take apart my A-pillar & start all over again. I appreciate the input!:thumb:
:tard:
he called my a tard. See that? :( lol
Sorry it didn't make sense the way you worded it...
1 - 7 of 7 Posts
