a friend of mine has a fass off of his 01 dodge that he is letting go cheap if i want it, im not sure it will work, does anyone know if it can be done?
Pretty sure it will, you will just need different fittings and lines.
iirc dodge has an LP that only pushes 7-15 psi depending on model. the fass 150 would work but it would need to be an adjustable unit or and adjustable unit with different gears. all depends on the model.
Out of the box it would work fine as a helper pump. You would need a new spring to bring it up if you wanted to run it as a stand alone pump.
