1 - 9 of 9 Posts
Just got an X3 and have read a lot about the performance tunes but not much on the difference between DJ's and Innovatives tow tunes. Also who is easier on the tranny?
I have an '04 6.0L Excursion
i have dj's tunes and love them ...have had no problems with them and the shifts seem perfect to me......and welcome to the org:thumb:
how much weight are you towing?
LTJDS
Answer to your ???
DO NOT RUN EITHER WITHOUT A PYRO/EGT AND A DEDICATED TRANNY TEMP GAUGE. THE REST IS UP FOR DEBATE. i HEAR SOME OF THE EXTREME / LOONEY TUNES (EITHER OR) run HOT ! But hat is in Performance Setting not TOW. JUST watch your gauges and know the factory tranny gauge is a Dummy gauge..:)
I use Eric's street tune to tow with and it has to be a long hard pull to get it to 1200*. The only reason I got that hot was I was experaminting to see how hot it would get, left it in 6th gear and pushed it a little more than normal. I always pull in 5th gear when climbing a grade and it will cruise up any hill at 60-65mph and not get over 1000*.
1 - 9 of 9 Posts
