1999 wvo system overview
Tell me if i got this straight. Im trying to put a system in my 2000 PSD. What i would need for it to work efficiently and correctly are as follows:
Tank with heating element.
two Fuel filters (1 right after the tank, 1 right before the pump)
Solenoid (pump:FASS, AIRDOG, etc)
FPHE
Hose
Tees
Feeds to hoses
I am uncertain on how the fuel is pushed from the tank to the filter then the FPHE then the pump and finally into the injectors.
All you will need is as follows:
A second tank
A heated fuel pickup(no need to heat entire tank)
heated fuel lines
fuel filter, better off heated, 12V like a racor 1000CF
more heated line
fuel switch, pollak 6 port valve
then fuel pump, I used my stock pump for 70k miles before it died, then upgraded to a FASS pump for $400
then more heated line tied in to fuel line at motor and coolant lines tied in at motor to heater core lines
let me know how I can help!
Green Machine.com
