1 - 16 of 16 Posts
Devilsown pump, works great, running it at about 125psi $120
3/8" inline filter, should pick up anything terrible before pump $3
8gal. Tank, I picked it up at either tractor supply or nothern tool, cant remember, but it was like $30
Hobbs style switches, I got them off coolingmists website, both for like $45, I tried the ones NAPA had but wasnt to thrilled with them
A brass T splits the pressurized line to each of the selnoids
2 Water selnoids I got from Mcmaster supply $75
Nozzles came from McMaster too, like $3 a nozzle, I bought every size they had, I am still experimenting with sizes
All in all so far I like it alot, I have been using 0F or -32F windshield washer fluid. The small nozzle I have coming on about 6psi, bigger one adds in at 18psi, I am thinking I am going to swap out the big one to one size bigger just for those WOT runs. If you are not a fan of wiring or fine tuning a system, buy one of the controllers, or just a kit. I am a third generation electrician in the making (lol) and it was cake for me.... but not so much for others. I have 2 switches in the cab, and a relay for key on power, three led's one for low activation, high activation, and one for low water level. As far as performance, I am able to stay in it longer, picked up about 3 lbs of boost, towing is awesome now. I pulled a 12k load (mini excavator) for 3 hours just Monday and sprayed the small shot the whole way, and big one came on when needed, I had no problems pulling that load 85-90 to pass people, and best of all never exceeded 1200F. Any questions feel free to ask, I'm not too good at the whole "write-up" thing.
OCONUS
Great job, and thanks for sharing.
PM SENT DUDE!!! gotta get the low down on this...ive been wanting to do this man...my egt's sore when i tow our mini X and skidsteer man...
you said you were expeirimenting with diff nozzles, well, i wonder if some 5.4 triton injectors would do any good??? i have 8 2004 model ford triton 5.4 injectors....wonder what they would do???
ummm, dont think the 5.4 injectors would work, I am running small water injectors... I am expiramenting with different size(flow) injectors... Bout to responf to pm
i got mine for 400 bucks with 7gph nozzles droppin 200 degrees, wanted to do by myself but i just didnt want to mess anything up and looks clean but good job :thumb:
Discussion Starter #11
Well, with my small shot, not seeing a whole lot just driving, maybe 50-75 degrees... Now towing with the small nozzle it helps alot esp in town. On the road pulling 12k 75-85 I am seeing a 150-200 degree drop.
In my extreme tune I can run WOT at 30lbs of boost and never exceed about 1250-1300 all the way to 100mph!!
what size nozzles are you running? should be stamped on the side. Might get some cooler temps with larger nozzles. Let me know and i will hlelp you out.
That tank you got from Northern tool, did it have a float in it to wire for your low water level?
Discussion Starter #14
Nope, I picked up the self sealing float from Devilsown:thumb:
Let me look, in the middle of a full stereo/interior project right now.
I'll post back, thanks:thumb::nod:
1 - 16 of 16 Posts
