Ok guys so last few days i have been trying to set up my own exhaust brakes and finally got it and i was wanting everyones opinion if you think it will work or not.
To explain it a little bit about this schematic. It uses the IVS switch on the accelerator pedal to control it. the relay that hooks to the brake master cylinder disarms the cursie control to prevent accidental setting and the exhaust brake coming on which as soon as the toggle is turned off the crusie will work again. The ivs switch Controls the other relay and when the pedal is released, the wire that you tie into on the ivs has 0 volts allowing the relay to switch to the 87a pin and energizing the the EBPV which in return shuts this valve and working as a exhaust brake. so what do you think? (please excuse if the schematic is crappy i am only 17 never done one before)
Warning i have not tried this set up yet on a truck
Idea came to me after helping my uncle install a accel exhaust brake.
