hey guys, i drive a 07 F 350 CCLB DRW 6.0, and i drive ALOT ! 38k miles in just over 1 year ! Any of yall care to direct me to the info i need to produce my own Bio Diesel? I sure would like to reduce my PAIN at the pump.
First things first....
Do you have WVO or new oil available to you? Also, the time and resources to make it?
I guess i have oil available, dont most people just ask restaurants for there waste oil?
Time? how much time is required? resources? explain
Oh boy.....
I HIGHLY recomend you have 1000 gallons in your posession before you worry about the above question
1000 gallons ? where am i going to store 1000 gal? I currently use around 3,000 gal of diesel per year. So i am wanting to make 100 gal per month bio diesel.
perhaps someone else can help me?, since i am wanting to produce a small quantity of bio diesel.
First step to QUALITY B100......4 replys and not one single person pointed me to a book on how to make Bi Diesel, or said how they started making Bio Diesel. I expected more info from verterans of this Forum. I guess i will do this on my own. Veggin psd, "tells me i got to start with 1,000gal or dont bother! Really ? i highly doubt any one starts with 1,000 gals of oil there first couple of batches. I am not out to start my own refinery.
I think i can get the oil, guy i work with, his brother in law owns a restaurant, so theres my oil .
Good luck on your own then.4 replys and not one single person pointed me to a book on how to make Bi Diesel, or said how they started making Bio Diesel. I expected more info from verterans of this Forum. I guess i will do this on my own. Veggin psd, "tells me i got to start with 1,000gal or dont bother! Really ? i highly doubt any one starts with 1,000 gals of oil there first couple of batches. I am not out to start my own refinery.
SHUT mouth. OPEN mind.
READ READ READ.
GOOGLE is you best friend.
I said 1000 gallons because judging by your line of questioning, you are clueless, and your later posts prove it. Thus, telling you 1000 gallons was a buffer, figuring you would find 500. That seems like a lot but it is not. If you are wanting to burn 100 gallons a month, buy it. I have spent tens of thousands of dollars and thousands of hours getting to where I am today. You will likely never achieve that, and surely wont do it on a forum. As far as WVO and B100 you can only learn so much from a forum. Remember, some inventing needed to occur along the way, and you pissed on the cheerios of one of the guys who have cracked a few nuts in the alternative fuel circle over the years. I can tell you the chemical formula for transesterfications and the conditions in which a complete reaction will occur and how to test for it, but I will not. You seem to know it all already.:doh:
Good luck.
Yes and no. Based on supply and demand at work, we may used what we haul in in our trucks or we may sell it to our customers. Some of the trucks will get gummed up fuel filters and run worse than others. Some will run just fine. One truck in particular will run alright with it if you run a full tank of straight diesel fuel through it once a week.Haha. Well now that the hostility is over with I have a question regarding bio diesel and/or "homemade" bio diesel. I have heard that these products have an undesirable effect on diesel injectors over time. Is this true and are there any other unwanted side effects to the alternative fuel?
Thank you in advance for any input on the subject.
Andrew
If you make good quailty bio then you should have no problems. If you don't then you most likely will experience that undesirable effect you are refering to.Haha. Well now that the hostility is over with I have a question regarding bio diesel and/or "homemade" bio diesel. I have heard that these products have an undesirable effect on diesel injectors over time. Is this true and are there any other unwanted side effects to the alternative fuel?
Andrew
