1 - 20 of 32 Posts
Vendor
Diode Dynamics Powerstroke License Plate LEDs! Plug & Play Install! Ships Same Day!
Ford Powerstroke License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Ford F-250 / F-350. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your truck!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your truck looks at night.
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs!
Bulb Design
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your F-250 / F-350).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
1997-2005 Ford F-150 License Plate LEDs
2006-2010 Ford F-150 License Plate LEDs
2011-2014 Ford F-150 License Plate LEDs
1999-2016 Ford F-250 Super Duty License Plate LEDs
1999-2016 Ford F-350 Super Duty License Plate LEDs
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
For a couple of bucks since one of mine is already super dim, ill bite.
Sent y'all an order.
Wish I had seen this first. Cheaper than SBL!
Vendor
Nick
whats a good 194 for a RV reading light ??
Hello!
Our HP3 produces 56 lumens and the HP5 produces 92 lumens (Measured). Depending on how much area you are trying to cover, I'd go with one of these bulb model options.
They are also available in 4000K / 5000K / 6000K color temperatures
Nick C.
Had just replaced a license plate light a month ago, wished I had seen this then. Though on mine, the bulbs are not replaceable, have to buy the whole lamp.
1 - 20 of 32 Posts
