The only way to do it right, is to determine the axleloads in your use acurate and look them back in a pressure/ loadcapacity list for the needed cold pressure.
If you then also give the maximum speed you use, and wont go over for even a minute, I can make a custum made pressure/axleloadcapacity-list for you, with build in maximum reserve, at wich comfort and gripp is still acceptable, so you dont need to do precalculations yourselfes.
Need from tires next.
1. Maximum load or loadindex
2. Loadrange of your LT to determine the maxloadpressure, but if you see AT xx psi, that is what I need.
3, speedcode, less important.
Then if for normal use, and you incidentially have to transport wood or stones from 3 blocks away, you dont need to highen up, if you use lower speed. For instance , my list gives 90% used of loadcapacity calculated for the pressure for 99mph Then if those stones transported, the tires still won't overheat. When using max 50mph.
