I have about 8500 miles on the 2020 F250. A couple of days ago i was going to clean the air filter. It is totally re-done, different than my prior 2018. Upon pulling it, i removed the foam type cover that had been installed over the actual filter. Per Ford tech it is there to quiet or deaden the sound.
Took a 220 mile drive today thru Alma, Breckinridge, Vail, and back home, all high altitude using cc. Double and triple jumped campers in the mountains hitting about 85, cruised mostly with 5 mph of the speed limit- 60-65 through mountains. Filled up at Divide on the way out, same pump topped of at return. Hand calculated 23 mpg.
Not bad...
Not bad...
