1 - 20 of 22 Posts
I've been alternating between adding Diesel Kleen and premixing with 2 stroke oil at 200:1. I was wondering how Diesel Kleen compares in lubricity to 2 stroke?
Administrator
Here is a link to the whole article http://www.dieselplace.com/forum/showthread.php?t=177728
below are the results
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
CREDITS:
This study would not have been possible without the participation of all companies involved and dieselplace.com. A special Thank You to all of the dieselplace.com members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer.
__________________
....7)Super Tech Outboard 2-cycle TC-W3 engine oil
200:1 ratio
16.64 oz/tank
$1.09/tank......
.... I've been using a whole gallon to a tank but I only put 2 cycle in when I do fill her all the way up.... which rarely happens :hehe:
Travis
i use 10 and occasionally 11 and i also use rev x additive. its whatever i got my my truck box is what i use lol
War is the answer!
XPD really is the best. I love it and I have tried it all.
Sent from my SGSIII running a custom ROM.
War is the answer!
I get it online. Last me about 6 months. Depending on how much I drive. I wish I could find it in stores but I can't and it the only thing I have ever noticed a difference after putting it in.
Diesel Kleen is 10 on the list. I'm sure it better than running nothing but I doubt it's doing much.
What makes it the best?
Administrator
the lubricity improvement chart put's it at # 2
and not everyone wants #1 in the form of BIO
however I always wondered why 2 stroke didn't bump the # more?
I use Opti Lube XPD. (just got 2 gallons at the door today). Have been out and while out used Diesel Clean.
IN the 7.3 I used diesel clean and 2 stroke.
The freaking BEST is when I see old school people think trans fluid helps. HAHAHAHAHAHA.
War is the answer!
Have you seen the test charts? That and my personal use. Its the only one I have used that I notice my truck runs better on. I have tried a LOT of them.
My truck loves two stroke and tranny fluid.
Runs quite, starts right up.
Is tranny fluid not good? I even run used tranny fluid and used motor oil. But used fluids tend to clog up my fuel filters, even though I pre filter the fluids.
Administrator
i think the tranny fluid is fine ,, but IDK if it has a benefit
but at the cost of filters I would avoid used oil in anything other than a 7.3
i run tcw3 2 stroke when I want the clatter reduced
I've used Diesel Clean and didn't notice much of a difference. I bought a case of Stanadyne Performance Formula and it seems to help with starting and the truck seems to run slightly smoother but it does nothing to quiet the truck and as far as how well it lubricates I'm not too sure.
I've been wanting to try 2-stroke but never know which kind to get :dunno:
I've heard some guys use outboard motor oil???
Never head of XPD until now, I'll have to give that a try next. Bottom line is anything is better than nothing :thumb:
I use 4oz of diesel kleen white and 12oz of 2-stroke in a 16oz bottle.
The diesel kleen is a concentrated formula. Its a 2.5 gallon that is more than half the price of the 80oz bottles at $14.
I don't use anything.... Am I missing out?
Tranny fluid? haha. I saw an article in diesel power about running your truck on used atf!!!!! holy cwap!
War is the answer!
I would say yes. It lubricates and raises the ctain levels to acceptable levels not to mention keeps the diesel from jelling in winter.
Trans fluid adds friction. Yes, there are some motors that can run on filtered down transfluid.
There is zero lubrication to diesel fuel from trans fluid.
Shoot some your diesel with transfluid over to blackstone. lol
1 - 20 of 22 Posts
