1 - 5 of 5 Posts
· Premium Member
'01 F350 7.3L, 4R100, CC, LB, 4x4
This will probably get you as many posts as there are additives. Members will share their favorites.
Diesel Kleen, XPD, Archoil are some of the front runners. Google "Diesel Additives" - you'll see a bunch more.
Reactions: john galt
· california deplorable
that pretty well covers it..
we're done here, it's a wrap :D
unless you want to get into the weird stuff like 2 stroke oil or tranny fluid :wink[3]:
· Registered
Where do you live? How cold is it getting. I would look at fixing the issue rather then using an additive. It should start no problem now that it is getting spring unless your in somewhere where it is still really cold. Maybe check glow plugs
· Registered
I have a 6.0 first of all....... but I was experiencing the same problem this winter. Slower and slower starts with 2-3 tries after cycling glow plugs to get the truck running.
Didn’t do any troubleshooting cause it was too cold here in the mitten but got lucky actually that the bendix (I think it’s called) finally went on the starter. It’s the motor that sends the sprocket on the starter to the flywheel. Anyhow I decided to replace the entire starter with a 6.4 unit and every single start issue was cured. Truck starts first try in -30 degrees zero Problems.
Back to you. Try putting a 6.4 starter on your 7.3. A google search shows that all 7.3,6.0,6.4,6.7 starters are compatible. This takes less than a half hour to do and I swear it will improve your situation. I was skeptic but words can not tell you how thankful I was that the guys here put me onto the 6.4 trick. The price tag sucks but buy a brand new starter and put it on. You won’t regret
1 - 5 of 5 Posts
