1 - 17 of 17 Posts
today was the day.
anyway this is what i got.
-10 gal distilled water from hyvee ($0.88 gal) = $8.88
- 3 gal of zerex elc-1 concentrate (ordered from Napa @ 19.99 gal x 3) = $59.97
- bottle of vc-9 (got from ford $32.00) = $32.00
- dozen glazed doughnuts that me and my buddy wiped out :hehe:
grand total = $108
plus $40 in diesel :thumb:
note- run your heat on high during the whole process. to flush heater core
#1 i drove it for about 5 min to get the t-stat open. pulled the pet**** and drained it (only get 3 gal at a time)
#2 filled it up with hose water. drove it for another 5-10 min. drained it again.
#3 topped it off with 3 gal of distilled. drove it another 5-10. drained it. do it one more time so you have mostly distilled water in the system.
#4 drain it. put your bottle of vc-9 and top with 3 gal of distilled.
#5 drive it! i took the interstate. went half hour out then turned around. 1 hour of drive time.
#6 drain it. leave the pet**** out. put the hose in top of the degas and run the truck for 20 min with water flushing through it.
after that the water coming out should be clean.
#7 repeat #3 to get all distilled back in the system
#8 drain the 3 gal out. and fill with 3 gal of coolant.
done! drive it and top it off with the distilled as needed. NO MORE COOLANT!!
does that sound right guys? or did i completely screw it up.
some of the nastiest coolant Ive ever seen came out of that thing. heres some pics.
word of advice. get a buddy to pull the pet**** when the coolant is hot :hehe:
first drain
yummy
another drain
the coolant
serious flush after the vc-9
hope this helps someone
coolant temps dropped 5 degrees on the highway after it was all said and done:dunno:
Discussion Starter · #2 ·
:bump::bump:
has to be somewhat useful
Good work man....I will do your same flush here in the next few days. A few questions for you....why did you use the VC9 vs the Restore plus? Also why did you choose what you did for the ELC? Did your delta change at all? Replace the thermastat?
today was the day. the dealer screwed around for the last time. so i pulled the plug on the whole works:mad: guess they dont want my $2400 :doh:
grand total = $108
first drain
yummy
another drain
the coolant
Great write up. Still like your "Raptor" grill.
Vc-9 and restore plus are the same thing. I only went with ford vc-9 because I was already there checking on an oil cooler.
Went with zerex because it was reasonably priced. Don't know how much cat was but they were 40 miles From me. I'm going to find out delta tomorrow. My matco scanner won't read eot :doh: and didn't replace the t-stat i replaced it 10k ago because it was stuck open.
Discussion Starter · #8 ·
Discussion Starter · #9 ·
Discussion Starter · #11 ·
there was a small amount of oil in my coolant. so im assuming its coming from the oil cooler :dunno:
2006 6.0 PSD
Bummer on the oil cooler.
That is my fear. I have 60K+ on my 06 and it looks like original coolant. Dealer report did not show major work on the motor. My temp delta is 6-10 degrees at 65 flat or mild hill. Thinking I will just watch temps and when they get to far apart have the warranty take care of it then swap the coolant.
Discussion Starter · #13 ·
hooked it up to the scanner and it droped 5 degrees at 65 mph. my new oil cooler and egr delete should be here mon
Any reason why you've got a massive photo in your signature line?
That is causin me a bit of a hard time scrollin threads on my laptop.
You should make that your profile pic, so people see it when they view your profile, rather than attach it to every post you make. :thumb:
Discussion Starter · #15 ·
Will do. Yea it pisses me off to when I'm on my phone :hehe:
Is this still the correct procedure for flushing?
Wait, I'm not getting how you got these past the coolant cap. :D
Nice write up, I'm getting ready to do that soon, my self. Not looking forward to it, as with three littel ones, it's hard to get that much dedicated time to do anything. lol
1 - 17 of 17 Posts
