1 - 9 of 9 Posts
What are the advantages of deleting the cat. conv.? I ordered a 4" exhaust turbo back, but it uses the factory cat. which is a 3" i believe. So if i'm putting a new 4" pipe,:dunno: it has to taper down to 3" factory cat. seems like i'm defeating the purpose of a 4" exhaust. need to get a cat delete pipe right? what about inspections ? put her back on? for that. am i thinking right?
What year is your truck? 7.3's don't require a cat for inspection. I would get a delete pipe and not worry about it. Or you could keep the cat and replace at inspection time..
DELETE PIPE
ITs a 1999 7.3 L. THE system i ordered (AFE alum.) does offer a delete pipe. I guess i can pick that up just about any wheres? or do you know of a good place to order one?
thanks
All 7.3L in the state of Arizona go through state inspections. Of course the 99 and up don't normally come with a cat. My 97 does.
I have the delete pipe on mine and it makes about 150* difference in lowering the EGT's.
But I have to put the CAT on at inspection time.
OH ITS GOT ONE. I'm not sure if they checked that last time r not. I guess it depends on where ya go. I'm guessin they do i'll just get the delete pipe and see what happens
Here is how I see it. If you have a delete pipe, then they know something has been removed. If you go with a complete kit then who is to say anything different.
Just my thought. And when I can afford a complete kit, I'll quit monkeying with the CAT.
Of course, I'm sure, that depends on the state.
Discussion Starter · #8 ·
DELETE PIPE
THE kit i ordered (turbo back) doesn't offer one (delete pipe) it uses the stock cat. doesn't matter if they know something been removed. down here i doubt they even check. Ill keep searching for a delete pipe
thanks
KVFD
get rid of it and get 50 bucks from the junk yard from it!! My truck didnt come with one so it was a plus!
1 - 9 of 9 Posts
