Im new to diesels for the most part and this morning had something happen that i thought was odd. First off its a 2002 F250 with 160k 7.3PSD. As usual i walked out to my truck, ignition to the on position while put my seatbelt on, waited for the coil light to turn off, it did. the went to crank. nada. in the past there has sometimes been a 1-2 second delay from when i try and crank the engine to when it actually cranks. today it didnt crank. turned key off and repeated. i held the key in the start position for about 7 seconda and it cranked over quickly and started, like it normally would.
my question is why is there a delay? should there be a delay? is it the actualy ignition switch? could it be the batteries? i doubt the batteries as it turned over quickly and powerfully as ever.
Any insight would be greatly appreciated. thanks guys
