1 - 11 of 11 Posts
I recently purchased a 2003 F-250, with the 7.3L, and I am new to the forum. Nothing works on the steering...neither the horn or the cruise control. I checked all the fuses and they are fine. Has anyone had this problem? Will I have to replace the steering wheel??? The overhead console doesn't work either, but I'm not as concerned about that. Would like my horn & cruise to work though. Any advice would be greatly appreciated!
Thanks,
Kevin
Ok, just Googled it and printed out a "how to" article.
Thanks for the info!!!!
Its a pretty easy deal, just be sure to unhook the batteries a few hours before working on it. And ALWAYS keep the air bag pointed away from you.
Follow up steering question; will an 08+ steering wheel fit in an 03 7.3?
No. The 08+ uses a hex style setup, while the 99-07 uses a splined setup. The 04-08 f150 uses the same as ours, but wiring is different.
If the dead zone is too large, then you have to turn the wheel a lot before your car actually starts to turn.
....hahaha. if you have that much dead zone, its time to fix something. Btw, OP asked about electrical death lol.
You get it fixed?
1 - 11 of 11 Posts
