1 - 5 of 5 Posts
hey guys, this data stream is off of my 95 ford psd. info is from my edge evolution.
engine prm: 630-670
EOT deg. F: 131
TFT deg. F: 80
Line pr. psi: 5
Exh. b/p: 15.7
so my question is, can anyone tell me if these numbers are typical of a 95 with 228K on it? or is there number on here that should be different for a healthy 7.3? truck runs good, just curious about the numbers because i have no clue what the typical numbers should be.:dunno: thanks in advance.
eot is engine oil temp,tft is tranny fluid temp,line pressure is in your tranny.and the last one is exuast back pressure and none of them look abnormal
thanks for the quick response. much appreciated:thumb:
just what all kinds of info and / or tests can you run with the edge set up on a 95 just curious
mine can do 0-60 time, 1/4 mile time. retrieve codes, data stream, and 60, 80 100hp settings
1 - 5 of 5 Posts
