1 - 9 of 9 Posts
PMR = JUNK
How do i remove the main dash panel? The big one that has the light switch and 4x4 switch on it. I don't wanna just start prying on things and break it. i am trying to get to the wires that run the "cruise" light in the gauge panel, so if there is an easier way to get to it let me know.
PMR = JUNK
Ok, thanks. Ha ha, so if it breaks ill blame you...
PMR = JUNK
nice truck by the way:thumb:
PMR = JUNK
Discussion Starter · #7 ·
grab and yank...ok yank along the clips..there are like 8 of them possibly more or less.
halps to have the wheel tilted down.
why are you chasing the cruise light wires..?
strange as it may seem I went from an e99 pcm to a pmt2 all the sudden I had a cruise light appear on the dash that was never lit before.
the back of the insterment cluster is also rather strange more of a printed ribbon circut board then wires...you also have to undo a small black thread loop that is your trany indicator to get the cluster out...(P R N D12 thingy)
PMR = JUNK
Discussion Starter · #9 ·
Im chasing the cruise light wire so i can run it in with my EBPV exhaust brake. I want to have it come on when i let off the throttle, but still be able to use the cruise. Might seem complicated but ive got it all figured out, all i need to do is find that wire and im good to go.
1 - 9 of 9 Posts
