1 - 9 of 9 Posts
I know I'm a 7.3 guy, but a nice guy from the floor above me had a question I couldn't answer so I am turning to you guys.
Guys brother has a 2004 6.0 Power Stroke with 100,XXX miles. When the truck is in cruise control for about 10-15 minutes and after he slows down to make a turn he lose power, he then has to pump the gas several times, soon after the truck will regain power but blow white smoke.
Any ideas?
Thanks guys,
-AJ
:icon_ford:
:bump: this kid needs help
Desert Shield/Storm Vet
Does the cruise control factor into the problem or does it occur without the cruise also? I would get it scaned for codes first and go from there:thumb:
The fella says its only when cruise control was on, never does it when its off, I guess a easy solution would be not to use the cruise, but on the highway it helps.
Don't use cruise? :dunno:
Discussion Starter · #7 ·
If it aint a CAT itsa DOG
Check the ICP sensor, injection control pressure.
Discussion Starter · #9 ·
1 - 9 of 9 Posts
