Ok guys love the forum,
Been reading it for a long time and just joined. Worked on cars my whole life and this is my second diesel (I am a GM guy...) Wanted to see what all the fuss was about with the 7.3
I have a weird question I can find the search function
Walk out to start my truck and nothing.
Cranks but no start
Pull out my scanner and showing a p1211 code and look at IPR pressure builds up to 80PSI while cranking (should be 500 to start)…
Check oil, a little low. Add oil
I poured oil into the HPOP started right up. Let it heat up and then shut it down…
Previously before this happen. I would start the truck cold and it would crank and then bogs down (sometimes shutting it off) if It didn’t shut down it would jump up in rpm and run fine with no problems.
Should I replace IPR? Could be just an O-ring I know but since I have it open... or am I in left field here?
I have the front of the truck torn apart to re due cooling system rebuild. (new wp/rad/hoses) I would like to fix this problem for good. I believe my HPOP is working properly. Also I don’t have a 3000lbs gauge to check actually pressures (I will buy one any recommendations?)
Any help would be great. Thanks
Cranks but no start
